RCC members subjected to predominantly bending and low value of axial force (tension or compression)
R Gurunathan
PostPosted: Sun Mar 31, 2024 8:30 am    Post subject: RCC members subjected to predominantly bending and low value of axial force (tension or compression) Reply with quote
Sub : RCC members subjected to predominantly bending and low value of axial force (tension or compression)
Reinforcement calculation for beams subjected to predominantly bending along with low value of compression or tension has not been addressed in IS456/SP16 so far.The available charts will give the solution with equal reinforcement i.e Asc=Ast.This is not appropriate due to the following reasons.
#1- For members subjected to high value of M & low value of P, the solution for the reinforcement with Asc=Ast,generally corresponds to Xu= 0.2d approximately and the design is uneconomical since section is not effectively utilized. This attachment gives the procedure for calculation of Asc/Ast for such cases based on equilibrium equations and formulae also given.
#2- For members subjected to high value of M &  low value of T,the solution for the reinforcement in SP16 with Asc=Ast is based on totally ignoring the concrete area which is very unfair.If we are to ignore the concrete area completely,then charts are not at all required  Based on equilibrium, simple equation Asc=Ast= M/(0.87Fy X d1)+ T/(2 X 0.87Fy) is sufficient which is same as sp-16.This attachment gives the procedure for such cases and formulae also given.(without ignoring the concrete area)
#3 -At present software providers are giving the design without following any standard procedure. For the same member design, we are getting different values  by different programmes. The professionals should ask for the validation of the programme used for the design from the vendors.They should also   take up this matter with IS code revision committee so that this aspect is addressed in the code IS 456.
I request you to go through the attachment giving the procedure and the formulae for calculation of reinforcements in beams subjected to low value of axial force and share the same to other engineers.After due diligence if found to be correct,please take it forward for incorporation in IS 456 by writing to prof C V R Murthy of IIT Madras who is heading the IS 456 revision committee.
(I have also forwarded this to Prof CVR Murthy of IIT Madras, (Chairman for IS 456 Committee) and requested him to include the same in revised version of IS 456/ or by amendment.Wnen contacted over phone on 13 th dec 2022,he informed that same would be taken up in the next sitting of the committee members.)
With Regards,
R Gurunathan-(9444398176)
On Fri, 29 Mar 2024 at 19:06, bsec <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            Dear AlpaI can not agree more with you. There is a definite increase in the frequency of structural failures in India. Bridges are more in the news due to their size, scale, visibility and its social and environmental impact. There is a National Group of IABSE of which DG, MoRT&H is the Chairman. I think the national group of IABSE is the right association to form a core group to get into the root cause analysis of failures of infrastructure in India.
Besides IABSE, I think IAStructE is doing a marvellous job of creating a platform by the name CROSFALL thru' which structural designers, contractors and clients can report about failures and near misses confidentially. I think this is a great opportunity which is not used by the structural engineering fraternity. As Editor of this journal I am struggling to get reports, despite the fact that we have so many failures and near misses.
Through this email, I am appealing all readers to contribute in CROSFALL without fear.
Best Wishes
Alok Bhowmick
FNAE, International PE (India)
Delegation Head (India), ING-fib
<img src="https://ci3.googleusercontent.com/mail-sig/AIorK4wkNzOGZPd7_QE7oqsbRta3zM_dCxeIm_01TZ_jtrxFlwUCY21f6Srn6WXPfNBtdIxJTfQndXg">
Managing Director
<img src="
https://ci3.googleusercontent.com/mail-sig/AIorK4xIQz5Y9deaydhfFEyd1WZdwe2qvWfVEhs4A1LQCnPwS2YbLNH03AAhrWK4hUIC_tJQOheK8-8">
B&S Engineering Consultants Pvt. Ltd.
315-316, Vishal Chambers, Sector 18, Noida; U.P - 201301
Tel: +91-120-4570703; 4310433; Mobile : +91-9811175255
Website :
www.bsecpl.in
       Winner of “IEI Industry Excellence Award 2022â€
       CEAI National Award winner for “Excellence in Engineering Consultancy Services†for 2017, 2018 & 2023
On Fri, Mar 29, 2024 at 2:43â€PM alpa_sheth forum@sefindia.org (forum@sefindia.org))> wrote:
V2_design-of-rcc-beams-subjected-to-bending-and-low-value-of-compression-or-tension_(1).pdf
 Filename:  V2_design-of-rcc-beams-subjected-to-bending-and-low-value-of-compression-or-tension_(1).pdf
 Filesize:  1.45 MB
 Downloaded:  35 Time(s)
