siddharth.subhedar at ... Guest
Posted: Tue Nov 07, 2006 6:10 am Post subject: Concrete: Seismic Design-Basic Questions |
Hi Kajal,
The research is going on but it is still not clear at what value of strength the material becomes classically brittle & the slope of the descending branch of the stress - strain curve becomes vertical and therefore not practically usable in design. In design, it is desirable that the concrete not crush or substantially enter the descending branch of the curve before the steel has reached its yield point. Above is the reason why codes do not specify a maximum limit on concrete grade for seismic resistant design.
Siddharth Subhedar
-----Original Message----- Message From kajal.chopra[AT]red... [mailto:kajal.chopra[AT]red...] Sent: Tuesday, November 07, 2006 1:01 AM To: SUBHEDAR Siddharth Subject: Concrete:Seismic Design-Basic Questions
I have some basic questions:
1.) As the concrete grade increases, the peak/crushing strain decreses?Hence concrete of higher grade has less ductility as it behaves in a more brittle mode due to less value of peak strain.
Then, why don't the codes specify a maximum limit on concrete grade for seismic resistant design?
2.)Modulus of Elasticity of concrete as per IS Code is given as 5000*squareroot(cube strength of concrete)
But , with reinforcement in it concrete would become more stiff.IS there any prescribe approximate value for reinforced concrete in any country code?
!-- Virus-Free Mail Using PostMaster Enterprise AvAc & QuickHeal Engine --!
------------------------------- Hincon Technoconsult Ltd, Mumbai, India
