parikshit_pandya SEFI Member
Posted: Thu Nov 09, 2006 10:48 am Post subject: nominal mix design |
Y Dear all,
what are the general thumb rules for nominal mix design?
Parikshit pandya
dipeshtanuja SEFI Member
Posted: Thu Nov 09, 2006 1:57 pm Post subject: nominal mix design |
Hi,
Regarding nominal mix design of reinfirced concrete M20 it is 1:2:3 of cement:sand:ageeregate with watercement ratio.
On Thu, 09 Nov 2006 parikshit_pandya[AT]red... wrote :
Parikshit pandya
rajmane ...
Posted: Fri Nov 10, 2006 10:59 am Post subject: nominal mix design |
10 Nov 2004
Dear all
I do not agree that nominal mix design of reinforced concrete M20 it is 1:2:3. For RCC. We have to always note that a design mix which should satisfy both strength (used in design of structures) and durability requirements (max. w/c ratio, minimum cement content, minimum grade, for a particular exposure condition) as per IS:456-2000. When we say RCC, I feel, we mean only structural concrete. Then durability requirements of Codes have to be ensured.
N P Rajamane Deputy Director and Head, Concrete Composites Lab, Structural Engg Research Centre, CSIR, Taramani, Chennai 600113 (Ph : 22549152 (D), 22549150 (CCLab), Res: 224417882) Email : rajmane[AT]ser..., rajamanenp[AT]yah...
PS : The above opinion is personal and it may not be necessarily the view of SERC.
Parikshit pandya
Akshaya.Das SEFI Member
Posted: Fri Nov 10, 2006 12:05 pm Post subject: nominal mix design |
Dear Sefian,
Here is some comment from a very experienced engineer in the construction field. I thought to share this with you all.
Dr A K Das
________________________________
Message From Basu, Pranab Sent: Friday, November 10, 2006 4:53 PM To: Das, Akshaya Subject: nominal mix design
I could not understand as to where from the discussion evolved? Unless you know the purpose, you might not contribute significantly. However like others, I can share my knowledge in the following manner.
1. First of all there is no terminology like Nominal Mix Design. Nominal Mix is a recommendation by IS 456 based on statistical data from several regions. Obviously the structural strength as well s the durability factor remained in consideration.
The Nominal Mix for M20concrete is 1:1.5:3, for M15 is 1:2:4
2. Design Mix is a design of concrete mix where all the actual design requirements as per the actual materials and working conditions are taken care of. The main design considerations are Structural Strength, Standard Deviation in strength, Durability of structure (minimum cement content), physical and chemical properties of building materials, exposure of the structure, workability factor and above al the available resources for commercial viability.
Design Mix is always an economic option but require technical competence.
I do not know how my vies can help one, if the problem or the issue is not known.
-----Original Message----- Message From Das, Akshaya Sent: Friday, November 10, 2006 4:31 PM To: Basu, Pranab Subject: FW: nominal mix design
Interesting discusiion!!!!!
Akshay
Message From rajmane[AT]ser... [mailto:rajmane[AT]ser...]
Sent: Friday, November 10, 2006 10:00 PM
To: Das, Akshaya
10 Nov 2004
Dear all
Quote: | On Thu, 09 Nov 2006 parikshit_pandya[AT]red... wrote :
Quote: | what are the general thumb rules for nominal mix design?
Quote: | email to ========powered by Reach1to1
Everywhere
This e-mail and any attachment are confidential and may be privileged or otherwise protected from disclosure. It is solely intended for the person(s) named above. If you are not the intended recipient, any reading, use, disclosure, copying or distribution of all or parts of this e-mail or associated attachments is strictly prohibited. If you are not an intended recipient, please notify the sender immediately by replying to this message or by telephone and delete this email and any attachments permanently from your system.
ranna ...
Posted: Sat Nov 11, 2006 6:15 am Post subject: nominal mix design |
nominal mix for M20 is 1:1.5:3
rajmane[AT]ser... wrote:
Quote: | 10 Nov 2004
Dear all
Hi,
Parikshit pandya
mkalgal Silver Sponsor
Posted: Mon Nov 13, 2006 4:52 am Post subject: nominal mix design |
Dear all I agree with Mr. Rajmane. Even if strength alone is the criteria, please do not use "thumb rules" for mix proportion!. We can get M10 with lots of water in 1:1.5:3 mix and M30 with controlled water cement ratio, graded aggregates and good particle packing! If proper mix design is not possible, do some trial castings. Regards Kalgal
On Sat Nov 11 11:45:57 2006, ranna[AT]bhe... <ranna[AT]bhe...> wrote:
10 Nov 2004
Dear all
Hi,
Parikshit pandya
rajmane ...
Posted: Mon Nov 13, 2006 12:20 pm Post subject: nominal mix design |
13 Nov 2004
Dear all
(1) I do not agree that nominal mixes are " The Nominal Mix for M20 concrete is 1:1.5:3, for M15 is 1:2:4". For RCC, we have to think of durability which is ensured by suitable adoption of w/c ratio. In the absence of inclusion of w/c ratio in defining the concrete mix or grade, the concretes can not be taken as acceptable. Defining/describing the concrete without w/c ratio should stop in the interest of the concrete constructions, especially, when the cement is produced in modern cement plants where high strength cements are easily and consistently produced and made available to engineers without much effect on final price.
(2) I am very glad about the following observation by Shri Basu, Pranab:
"Design Mix is a design of concrete mix where all the actual design requirements as per the actual materials and working conditions are taken care of. The main design considerations are Structural Strength, Standard Deviation in strength, Durability of structure (minimum cement content), physical and chemical properties of building materials, exposure of the structure, workability factor and above al the available resources for commercial viability."
However, I wish to add that the words "Durability of structure (minimum cement content)" should be replaced with "Durability of structure (minimum cement content, max. w/c ratio, minimum grade, for a particular exposure condition)".
(3) Let us accept important observations of Prof. Kalgal. A given mix proportion can give a wide range strengths, say ranging even from as less as 10 MPa to as high as 100 MPa depending upon several factors such as type and strength of cement strength, w/c ratio, presence/absence of mineral and chemical admixtures, type of mixer machine, transportation, placing and curing operations, age, etc.
Yours sincerely
Akshaya.Das[AT]ake... wrote:
Dr A K Das
Akshay
To: Das, Akshaya
10 Nov 2004
Dear all
Quote: | Regarding nominal mix design of reinfirced concrete M20 it is 1:2:3 of
Quote: | Quote: | what are the general thumb rules for nominal mix design?
Quote: | Quote: | email to ========powered by Reach1to1
Everywhere
sidhudaljeet ...
Posted: Mon Nov 13, 2006 5:27 pm Post subject: nominal mix design |
Dear N P Rajamane 1:1.5:3 for M-20 was used for hand mixed non vibrator concretes with water cement ratio based on water (5% of aggregates + 30% of cement ) Thus water cement ratio of 0.525. I think even today if you use hand mixed concrete and don’t use vibrator 33 grade OPC cement and water cement ratio 0.525, M-20 would be a great achievement. Daljeet rajmane[AT]ser... wrote:
13 Nov 2004
Dear all
Yours sincerely
Dr A K Das
Akshay
To: Das, Akshaya
10 Nov 2004
Dear all
Everywhere
Find out what India is talking about on - Yahoo! Answers India Send FREE SMS to your friend's mobile from Yahoo! Messenger Version 8. Get it NOW
