Very Fundamental Question
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2006
shankarciv
PostPosted: Sun Nov 12, 2006 6:39 am    Post subject: Very Fundamental Question Reply with quote
Hello:
A hinged support is one which gives reaction in both horizontal and vertical direction?That means at the location we have the hinged support there is no vertical translation nor any horizontal translation.Right?
But, the members of a truss are assumed to be connected by frictionless hinges.Right?But, there the hinge can translate vertically or horizontally.Right?But, this is contradictory to the assumption  in case of a hinged support as mentioned above???Why??
Please help!!
mkalgal
Silver Sponsor
Silver Sponsor
PostPosted: Mon Nov 13, 2006 4:46 am    Post subject: Very Fundamental Question Reply with quote
Dear Shankar,
This has reference to your query on hinged support and hinged joint of
a truss. One is a hinge which is supported and the other is not
supported. Since the hinge at a support is "fixed" to the support, it
would not allow any translation. At a "roller-hinge" end also we have
a hinge but it will allow translation in one direction isn't it?
Kalgal
On Sun Nov 12 12:09:53 2006, shankarciv[AT]red...
<shankarciv[AT]red...> wrote:
Hello:
Please help!!
anurag.sinha
PostPosted: Mon Nov 13, 2006 5:30 am    Post subject: Very Fundamental Question Reply with quote
The answer is also "Very Fundamental"
But the support can also sink and sway at the same time. Right?
Nothing is rigid, even the earth and the solar system is in motion.
shankarciv[AT]red... wrote:
Hello:
Please help!!
MAIL HAS BEEN SCANNED BY MACFEE
dbhanuprasad
PostPosted: Mon Nov 13, 2006 3:17 pm    Post subject: Very Fundamental Question Reply with quote
The support is assumed to be rigid and hence the support displacements
are assumed as zero. If the support is not rigid and it sinks or sways
the magnitude of the sinking/swaying shall be considered in the
analysis of structure. The structure becomes indeterminate and
normally such structures are analysed using structural analysis
softwares.
The effect of earth or solar system moving is negligible on the
building structures both from the size and loads (which are due to
gravity) consideration.
On Mon Nov 13 11:00:40 2006, anurag.sinha[AT]eil...
Hello:
Please help!!
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2006 All times are GMT
