dipeshtanuja at yahoo.... Guest
Posted: Mon Nov 13, 2006 7:35 am Post subject: design of slab |
Hi friends,
is it necessary to desgn the slab contineous to all adjecent panal or simply supported on beams?
Find out what India is talking about on - Yahoo! Answers India Send FREE SMS to your friend's mobile from Yahoo! Messenger Version 8. Get it NOW
sdec SEFI Regulars
Posted: Mon Nov 13, 2006 9:36 am Post subject: design of slab |
Dear Dipes Please go thru the Appendix E of IS 456 where the edge conditions and the subsequent selection of coefficients for slab design have been explained in detail. The continuity of slab being designed has to be realistic and based on the actual edge conditions in your framing plans;pl let me know if you still have any doubts after u go thru the Code. Regards Sangeeta
sdec SEFI Regulars
Posted: Mon Nov 13, 2006 9:42 am Post subject: design of slab |
dbhanuprasad SEFI Regulars
Posted: Mon Nov 13, 2006 1:21 pm Post subject: design of slab |
Whenever there is continuity of slab it should be considered in the design as the Moments develop at support and reinforcement should be provided at top over supports. If simply supported condition (i.e discontinous at support) is assumed then the moment developed at support is considered as zero and no rft is provided at top over support (except for nominal rft) and the slab will crack above support though the slab may not collapse as the rft at mid span would be suffficient for strength.
On Mon Nov 13 15:12:38 2006, sdec.in[AT]gma... <sdec.in[AT]gma...> wrote: [quote]Dear Dipes Please go thru the Appendix E of IS 456 where the edge conditions and the subsequent selection of coefficients for slab design have been explained in detail. The continuity of slab being designed has to be realistic and based on the actual edge conditions in your framing plans;pl let me know if you still have any doubts after u go thru the Code. Regards Sangeeta
