pkm1526 SEFI Member
Posted: Thu Dec 21, 2006 4:36 am Post subject: Daily Digest Thu Dec 21 00:00:04 2006 |
Dear Shekhar Panandiker
Thanks for your kind reply.
Do you we do'nt need any steel in colomn flared porion ? As in trepezidal footing we do not provide any steel on sloped face ?
As the drop portion is subjected to compression, it does not require any steel from bending consideration
kindly clarify
Thanks & regards
Prashant
wrote: ------------------------- Message From pkm1526[AT]yah... Subject: Flat Slab Design Date: 20/12/06 Time: 10:49:46 ------------------------- Dear Sefians
I have a question related to flat slab design, request experts to kindly advise me.
1) Any special reinforcement is required in column head ( Flared porion) or only columns main reinforcement is enough. 2) Is there any reinforcement requird in drop bottom layer, let us say we have 200 mm thick flat slab and at drop thickness is 250 ,so the bottom steel of flat slab continue only at 200 mm level, but what about steel at 250 mm level, here distance is refered from slab top surface.
Kindly give your suggestions or any reference which talk in detail on detailing of flat slab
Prashant
around
------------------------- Message From skanagasundaram[AT]gma... Subject: Cheap Structural Softwares??? Date: 20/12/06 Time: 17:45:44 ------------------------- Is it possible to get IS Codes CD. Pls advise.
tks sundaram
On Fri Dec 15 10:10:55 2006, cracksoft[AT]red... < cracksoft[AT]red...> wrote:
Quote: | Dear Friends,
Why we should use Cracked software ?
1) If you are a small consultant and can not afford multiple licenses of the software, 2) You want to learn new software but do not want to buy legal until and unless you are not confident about it,
We are not promoters of Cracked software but facilitator. At times you have to use it.
Please have a look on below list of Cracked Software available. We gurantee full versions.
If any software is not available which you are looking for in below list, please write to us, we will arrange it for you.
Thanks, CrackSoft
ABBYY_PDF_Transformer
PDF to Word or Excel Converter with out any data loss.
ADAPT ABI V4.50.3
Bridge Design Software, www.adaptsoft.com
ADAPT PT
Post Tensioning Software for Beam & Slab, www.adaptsoft.com
AFES Foundation
Automatic Foundation Design Software, www.ramcadds.in
Ansys V 10
Finite Element Analysis Software, www.ansys.com
Auto DWG to PDF Converter
Auto PDF to DWG.Converter
PDF to DWG or DXF Converter, Good Utility Software
Autodesk CIVIL 3D
Road DESIGN, www.autodesk.com
Autodesk CIVIL Design Companion
Road DESIGN, add on Utility www.autodesk.com
Autodesk Land Desktop
Bentley InRoads Suite 2004
Road DESIGN, www.bentley.com
Bentley MX Road 2004 Edition
CAESAR II V 4.5
Pipe Stress Analysis & Design, www.coade.com
Coade Tank 2.5
Tank analysis & Design, www.coade.com
CadWorx Plant Professional V 2006
Drafting Software, www.coade.com
CSI SAFE V 8.0.8
Raft or flat slab Analysis & Design, www.csiberkeley.com
Etabs V 9.1.1
Frame Analysis & Design , www.csiberkeley.com
Geo-Slope Geo Studio 2004
Geo-Technical Software, www.geo-slope.com
Graitec Advance Steel V6.1
Steel Detailing Software, www.graitec.com
GT Strudl V 27
Structural Analysis & Design Software, www.gtstrudl.gatech.edu
IS Codes
PDF Files of 1900 IS Codes related to Civil Engg, printable, copyable
LUSAS FEA V 13.5
Bridge Design Software, www.lusas.com
Mathcad 13
Mathematical calculations, www.mathcad.com
MIDAS CIVIL V 6.3
Bridge Design Software, www.imbsen.com/Midas.htm
Nisa Civil V 14
Structural Analysis & Design Software, www.nisasoftware.com
PDMS V 11.5
Aveva PDMS (Plant Design), www.aveva.com
PLAXIS
Geo-Technical, Finite Element code for Soil & Rock, www.plaxis.nl
Primavera Project Planner V 5
Project planning software, www.primavera.com
ProSteel 3D V17.1_Acad2007
Steel Detailing Software, www.structsoftsolutions.com
PvElite V 2005
Pressure Vessel Analysis Software, www.coade.com
RAM Concept V 1.2
Post-Tensioning Software, www.ramint.com
Revit Building V 9
Architectural Software , www.autodesk.com
Revit Structure V 2.0
Structural Software , www.autodesk.com
Risa 3D V 5.5
Structural Analysis & Design Software, www.risatech.com
Robobat V 17.5 Full
Structural Analysis & Design Software, www. robot-structures.com
SACS V 5.2
Offshore Structural Analysis & Design Software, www.sacs-edi.com
SAP 2000 V 10.0.7
Structural Analysis & Design Software, www.csiberkeley.com
SDS2
Steel Detailing Software, www.dsndata.com
STAAD.Pro V 2006
Structural Analysis & Design Software, www.reiworld.com
STRAP V 12
Structural Analysis & Design Software, www.ramcadds.in
StruCAD V11.0
Steel Detailing Software, www.acecad.co.uk
STRUDS V 2005 Advanced
Structural Analysis & Design Software, www.softtech-engr.com
TDV RM 2004 V 9.15.03
Bridge Design Software, www.tdv.at
Wallap V 5.03
Diaphram Wall Analysis Software, www.geosolve.co.uk
XSTEEL V 12 with SP3
Steel Detailing Software , www.tekla.com
------------------------- Message From civil[AT]gar... Subject: Flat Slab Design Date: 20/12/06 Time: 18:13:26 ------------------------- Dear Prashant,
The enlarged portion of coloumn is called capital of the coloumn and yes it has reinforcement in the conical shape without which there is no meaning to the coloumn capital. This is done do resist the punching shear caused due to small portion of colomn on the slab (reaction).
As far as double reinforcement in the slab is concerned it is to be calculated in the design.
Hope this solves your queries.
Sachin Kulkarni 98500-79070.
raju_goa SEFI Regulars
Posted: Sat Dec 23, 2006 1:31 pm Post subject: Daily Digest Thu Dec 21 00:00:04 2006 |
Dear Prashant, Flat slab systems are two way systems in which the load is resisted in two principal directions. Theseare beamless structures in which slab rests directly on columns. The column supporting a flat slab floor has a tendency to punch through the slab.In order to protect the structure against punching effect, slab portions around columns are made 25 % to 50% thicker ( called drops) and or columns are given brackets all around at their junctions with slab ( called capitals) The code gives two methods of design of flat slab structures 1. Empirical method and 2. Equivalent frame method. The equivalent frame method has a wider application and it can be used to situations of unequal spans as well.The flat slab systems are very efficient in resisting vertical loads but are very weak in resisting horizonatl loads.Thus these systems are best used in short buildings say upto four storeys where horizonatl loads can be resisted by brick walls enclosing the building.In taller buildings( say 4 to 8 storeys), the moments due to horizonatl loads are to be resisted by frames formed by column strips with the supporting columns.As the depth of the drop slab and that of the flat slab are less in value, more steel is consumed in resisting horizontal loads. In building of more than 8 storeys, shear walls or shear cores are provided to resist the entire horizonatl shear so that flat slab system with columns will resist only vertical load. This arrangemet gives an efficient structural system for both vertical and horizontal loads. We do need reinforcement in column heads.I hope I have cleared your doubts. Thanks,
Regards, Shekhar
SHEKHAR PANANDIKER & ASSOCIATES Consulting Structural Engineers Wing A, second floor, Heeraniketan, Margao - Goa 403601 INDIA
Tel:+91-832-2738399, 2705947 Fax:+91-832-2705947 Our new E-mail id is: panandiker_goa[AT]dat... . Please reply on our new E-mail id in future
