numbering pattern in STAAD
sandeepb
PostPosted: Tue Jan 06, 2009 9:56 am    Post subject: numbering pattern in STAAD Reply with quote
hi, while adding beams or plates... is there any pattern to follow
like clockwise/anticlockwise (at the time of choosing nodes)? what is
the professional way to do ??
Thankful People
vigneshlt
PostPosted: Tue Jan 06, 2009 10:47 am    Post subject: numbering pattern in STAAD Reply with quote
Use uniform patterning over entire model . otherwise the element local axis will be changed .
See the example files n check how the local axis is oriented accordingly –depends on software you r using
(press ctrl+o to see local axis orientation in staad pro)
I follow the below pattern
eg. Left to right, bottom to top (line elements) and same way for plates (anti clock wise from left bottom)
Thanks & Regards
VIGNESH R
Sent: Tuesday, January 06, 2009 3:53 PM
Subject: [SEFI] numbering pattern in STAAD
"This Message and its contents is intended solely for the addressee and is proprietary.Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T ECC.If you are not the addressee please return the mail to the sender.L&T ECC DIVISION"
PrachiThube
PostPosted: Tue Jan 06, 2009 12:25 pm    Post subject: Numbering pattern in STAAD Reply with quote
Dear All
       One can change the orientation of members at any time by using redefine incidences command (Select the members u want to change the orientations >> go to Tools>> go to Redefine Incidence>> and change the incidences as per ur requirements)
Thanks And Regards
P. Thube
