design of flat slabs- suitable software packages
k.gangadharan
PostPosted: Fri Jan 30, 2009 3:00 am    Post subject: design of flat slabs- suitable software packages Reply with quote
Dear Dr. M.Kalgal
During the e-conference on flat slabs, in your reply to mr. Alok's question ,regarding the use of 'ADAPT' software for analysis and design of flat slab buildings, you have replied that there are 'other software packages  with IS modules fitted in' .
I wish to know from you which are the other softwares which are preferred by consultants  with specific guidance for distribution of lateral load forces between  shear walls and columns? Please give  a list  popular and easy to use software packages which are good for analysis & design of flat slab structures, in your experience.
Another thing I wish to emphasize is that  during the  course of the discussions many speakers were pointing out the  Indian codes does not contain proper directions and guidance  and enough provisions to enable one to carry out a proper analysis and design of flat slabs and  lacks provisions for a safe design of flat slab structures and they therefore use ACI codes for this purpose.
ACI codes contain many practical  provisions for a safe analysis and design of flat slab structures and in that case Is there any objections in using softwares with ACI modules for designing flat slab projects in indian context.
Please give clear clarification in this matter.The other moderator  dr. Rai from IIT kanpur can also offer his remarks in the matter
with warm regards
Gangadharan.K
structural consultant
Rajiv
Diamond Sponsor
Diamond Sponsor
PostPosted: Fri Jan 30, 2009 7:51 am    Post subject: design of flat slabs- suitable software packages Reply with quote
Dear Mr. Gangadharan:
The software for flat slab design which is exceptional for ease in use and robustness is SAFE. This is available in India through CSI's local office in Delhi and it is not expensive.
Rajiv
----- Original Message -----
Sent: Friday, January 30, 2009 8:30 AM
Subject: [SEFI] design of flat slabs- suitable software packages
Dear Dr. M.Kalgal
with warm regards
Gangadharan.K
anujdalvi
PostPosted: Fri Jan 30, 2009 5:31 pm    Post subject: design of flat slabs- suitable software packages Reply with quote
Dear Friends,
I have designed an RCC structure which has a sitting space with a slab at double height,Now it was required by architecture that the sitting hall which is having max width of 14.50 m to be designed free of any columns,So for this span I have a beam of 300 x 1000 mm supported on 500 x 500 mm columns.We have ensured that no equipments are positioned on the slab panel adjacent to this configuration.We follow BS codes,ACI also is reffered and I have checked for servicibility as per both.I also happen to do a staad model to ensure a deflection of just 26 mm as against a value of L/500 permissible.
What I believe is that softwares like Etabs or Orion consider concrete to be purely elastic,as concerns the deflection the contribution of reinforcements is ignored ( probably).Now can any one discuss their expiriences with such span designs in past,also in case you adopted any different approach which you can share.
Thanks and Regards,
Anuj R Dalvi.
On 1/30/09, assekg <forum@sefindia.org (forum@sefindia.org)> wrote:
  Dear Dr. M.Kalgal
with warm regards
Gangadharan.K
ibarua
PostPosted: Sun Feb 01, 2009 7:18 am    Post subject: design of flat slabs- suitable softw Reply with quote
1/2/2009
1.  Calculation of deflection has obviously to be done for service loads only.
2.  Sectional properties will be computed using gross concrete section only; contribution of rebars may be safely ignored.
3. Use of computer software without understanding basics of structural response and without understanding the basic principles and assumptions of the software is not advisable. Software is written by humans and is therefore subject to human error.
Indrajit Barua.
On Fri, 30 Jan 2009 anujdalvi wrote :
Dear Friends,
permissible.
Thanks and Regards,
Anuj R Dalvi.
Dear Dr. M.Kalgal
your experience.
purpose.
indian context.
with warm regards
Gangadharan.K
mkalgal
PostPosted: Thu Feb 05, 2009 7:16 am    Post subject: Reply with quote
Dear Mr. Gangadharan,
Sorry for the delayed reply. I do not get time to browse this very interesting site everyday.
Most of the software that I knew of were capable of carrying out floor by floor analysis of flat slabs in the presence of Prestress, that too for gravity loads only. In addition to ADAPT FLOOR and SAFE from CSI(which claims to take into consideration lateral loads also), CEDRUS-5 from CUBUS (http://www.cubus.co.in), Post Tension India Pvt. Ltd, Vadodara have Indian Codes built in. NISA Civil was also working on a PT sub-routine. You may kindly check with CRANE Software India on this.
As has been discussed many times, the flat slab is treated purely as a diaphragm transferring lateral load effects to members capable of handling them like shear walls and core walls. The floor by floor analysis software gives the shear and moment at column locations due to gravity loading, which are inputted as joint forces in frame analysis to get at the actual values under different load combinations. Additional HYSD bars are added at each location to aid PT forces in handling the final forces/moments under ULS and SLS cases.
Well, I am out of touch with design of PT flat slabs for some time now and might have become outdated already!! I stand corrected if my statements above are not true now.
Dr. M. R. Kalgal
