Md Waqquar Ahmad SEFI Member
Posted: Sun Sep 13, 2009 8:24 am Post subject: Minimum Size & Thickness of Steel Section |
Respected Sir,
As per IS 800:2007 the minimum thickness of steel is not specified, Please let me know what is the minimum thickness and what is the minimum size of steel section (Angle, ISMC, ISNT,ISHT,ISST, ISLT,ISJT,ISMB,ISSC,ISHB) is being practiced in India.
As in the steel table (IS 808) there are some smaller section also which are not being used.
And i Also want to know that is SP 38 new Edition is available in market , which is as per New Code IS 800:2007.
The reason behind this is that i am doing my final year Mtech Structure Project in steel, if SP 38 as per new code is not available in market i will try do it with new Code. If you have any suggestion regarding the same feel free to give it to me it will make me proud.
Thanking you in Anticipation, |
sspawar ...
Posted: Mon Sep 14, 2009 5:37 am Post subject: |
Dear Mr. Ahmed,
As per latest catlouge(Nov 2008) and my knowledge -SP38-1987 is still active. Further new edition is not issued from BIS.
I am pasting here a list of Codes related to the Stru Sections mainly 801 and 811 is partaing to the light section.
Str Sections.
No. - Standard Description Reaffirmed No. of Amd.
1 IS 808 : 1989 Dimensions for Hot Rolled Steel Beam, Column, Channel and Angle Sections 2004 1
2 IS 811 : 1987 Cold formed light gauge structural steel sections 2004 3 IS 1173 : 1978 Hot rolled slit steel tee bars 2004
4 IS 1252 : 1991 Dimensions of hot rolled steel bulb angles 2003
5 IS 1730 : 1989 Dimensions for steel plates,sheets strips and flats for general engineering purposes 2004
6 IS 1732 : 1989 Dimensions for round and square steel bars for structural and general engineering purposes 2004
7 IS 1852 : 1985 Rolling and cutting tolerances for hot rolled steel products 2003 2
8 IS 1863 : 1979 Hot rolled steel bulb flats 2004
9 IS 1864 : 1979 Hot-rolled steel L-sections for shipbuilding 2004
10 IS 2314 : 1986 Specification for Steel Sheet Piling Sections 2003
11 IS 2713 : Parts I to III : 1980 Specification for Tubular Steel Poles for Overhead Power Lines 2003 1
12 IS 3443 : 1980 Crane rail sections 2004 1
13 IS 3908 : 1986 Aluminium equal leg angles 2003
14 IS 3909 : 1986 Specification for Aluminium Unequal Leg Angles 2003
15 IS 3921 : 1985 Aluminium channels 2006
16 IS 3954 : 1991 Hot Rolled Steel Channel Sections for General Engineering Purposes - Dimensions 2006
17 IS 3964 : 1980 Light rails 2006
18 IS 5384 : 1985 Aluminium I-beam 2006
19 IS 5488 : 1987 Dimensions and dimensional tolerances for hot rolled steel plates for ship's hull structure 2004
20 IS 6445 : 1985 Aluminium tee-sections 2006
21 IS 6449 : 1987 Aluminium bulb angles for marine application 2004
22 IS 6475 : 1987 Aluminium tee bars for marine application 2004
23 IS 6476 : 1987 Aluminium bulb plates for marine application 2004
24 IS 7452 : 1990 Specificatiion for hot-rolled steel sections for doors, windows and ventilators 2003
25 IS 10182 : Part I : 1982 Dimensions and Tolerances for Hot Rolled Track Shoe Sections - Part I : Section TS-L1 2006
26 IS 10182 : Part 2 : 1985 Dimensions and tolerances for hot-rolled track shoe sections 2006
27 IS 12779 : 1989 Rolling and cutting tolerances for hot rolled parallel flange beam and column sections 2004
Struc Engineering
.No. Standard Description Reaffirmed No. of Amd.
1 SP 6 : Part 1 : 1964 Handbook for structural engineers - Structural steel sections 2003
2 SP 6 : Part 2 : 1962 Handbook For Structural Engineers - 2 : Steel Beams and Plate Girders 2003
3 SP 6 : Part 3 : 1962 Handbook Structural Engineers - Part 3 : Steel Columns and Struts 2003
4 SP 6 : Part 4 : 1969 ISI Handbook for Structural Engineers 4. Use of High Strength Friction Grip Bolts 2001
5 SP 6 : Part 5 : 1980 Handbook for structural engineers - Cold-formed, light gauge steel structures 2001 1
6 SP 6 : Part 6 : 1972 Handbook for structural engineers - Application of plastic theory in design of steel structures 2001
7 SP 38 (S and T) : 1987 Handbook of Typified Designs for Structures with Steel Roof Trusses (with and without Cranes) (Based on is Codes)
8 SP 40 (S and T) : 1987 Handbook on Structures with Steel Portal Frames
9 SP 47 (S and T) : 1988 Handbook on Structures with Steel Lattice Portal Frames (Without Cranes)
10 IS 800 : 2007 General Construction in Steel - Code of Practice
11 IS 801 : 1975 Code of practice for use of cold formed light gauge steel structural members in general building construction 2006 112 IS 802 : Part 1 : Sec 1 : 1995 Code of practice for use of structural steel in overhead transmission line towers, Part 1 Materials and Loads and permissible stresses Section 1 Materials and Loads 2006
13 IS 802 : Part 1 : Sec 2 : 1992 Code of practice for use of structural steel in overhead transmission line towers Part 1 : Material, loads and permissible stress Section 2 Permissible stress 2003 1
14 IS 802 : Part II : 1978 Code of Practice for Use of Structural Steel in Overhead Transmission Line Towers - Part II : Fabrication, Galvanizing, Inspection and Packing 2006 1
15 IS 802 : Part 3 : 1978 Code of practice for use of structural steel in overhead transmission line towers, part 3 Testing 2003
16 IS 803 : 1976 Code of Practice for Design Fabrication and Erection of Vertical Mild Steel Cylindrical Welded Oil Storage Tanks 2006 1
17 IS 804 : 1967 Rectangular pressed steel tanks 2003 2
18 IS 805 : 1968 Code of Practice for Use of Steel in Gravity Water Tanks 2006
19 IS 806 : 1968 Code of practice for use of steel tubes in general building construction 2002 1
20 IS 2750 : 1964 Specification for Steel Scaffoldings 2006 3
21 IS 4000 : 1992 Code of practice for high strength bolts in steel structures 2003
22 IS 4014 : Part 1 : 1967 Code of practice for steel tubular scaffolding Part 1 Definitions and materials 2006
23 IS 6533 : Part 1 : 1989 Code of practice for design and construction of steel chimneys Part 1 Mechanical aspects ) 2006 1
24 IS 6533 : Part 2 : 1989 Code of practice for design and construction of steel chimneys Part 2 Structural aspects 2003 1
25 IS 7205 : 1974 Safety Code for Erection of Structural Steelwork 2006
26 IS 7215 : 1974 Tolerances for fabrication of steel structures 2006 1
27 IS 8081 : 1976 Specification for slotted sections 2006 1
28 IS 8147 : 1976 Code of Practice for Use of Aluminium Alloys in Structures 2006
29 IS 8640 : 1977 Recommendations for dimensional parameters for industrial building 2006
30 IS 9178 : Part 1 : 1979 Criteria for design of steel bins for storage of bulk materials Part 1 General requirements and assessment of loads 2006 2
31 IS 9178 : Part 2 : 1979 Criteria for design of steel bins for storage of bulk material Part 2 Design storage criteria 2006
32 IS 9178 : Part 3 : 1980 Criteria for design of steel bins for storage of bulk materials Part 3 Bins designed for mass flow and funnel flow 2006 1
33 IS 9964 : Part 1 : 1981 Recommendations for maintenance and operation of petroleum storage tanks Part 1 Preparation of tanks for safe entry and work 2006
34 IS 9964 : Part II : 1981 Recommendations for Maintenance and Operation of Petroleum Storage Tanks - Part II : Inspection 2006
35 IS 10987 : 1992 Code of practice for design, fabrication, testing and installation of underground/above ground horizontal cyclindrical storage tanks for petroleum products 2003
36 IS 12778 : 2004 Hot Rolled Parallel Flange Steel Sections for Beams, Columns and Bearing Piles - Dimensions and Section Properties
37 IS 12843 : 1989 Tolerances for erection of steel structures 2006
38 IS 15663 : Part 1 : 2006 Design and Installation of Natural Gas Pipelines - Code of Practice - Part 1 : Laying of Pipelines
39 IS 15663 : Part 2 : 2006 Design and Installation of Natural Gas Pipelines - Code of Practice - Part 2 : Laying of Pipelines in Crossings
40 IS 15663 : Part 3 : 2006 Design and Installation of Natural Gas Pipelines - Code of Practice - Part 3 : Pre-Commissioning and Commissioning of Pipelines |
arulsteel General Sponsor
Posted: Mon Sep 14, 2009 8:44 am Post subject: Minimum Size & Thickness of Steel Section |
Dear Mr.Waqquar Bhai
Happy to know your interest in IS:800(2007). Yes the minimum thickness restrictions have been removed in the new code - however a chapter has been added on durablity. The minimum thickness must be decided based on the exposure condition of the steel structures and also based on the aggressive nature of the environment. The normal rule is that if steel is put in an enclosure away from diurnal wetting and drying, there is no need for mimimum thickness requirements.
You have a happy news that SP:38 is not available and please go ahead and produce one of your own using the new IS:800(2007). Please share it with us so that we can even have a document which may be published by BIS after a peer review process. Waqquar Bhai! good effort go ahead! Inshah Alla make it in your PG dissertation. Tata Structura is developing a document something similar to SP:38 but dedicated to tubular sections. This work is being pursued at IIT Madras. Tata Structura may make that publication free. In case of doubts please be in touch or send a mail to Prof.Satish at kim@iitm.ac.in (kim@iitm.ac.in) regarding the work on tubular trusses.
arul(serc)
Sent: Sunday, 13 September, 2009 1:54:55 PM
Subject: [SEFI] Minimum Size & Thickness of Steel Section
Respected Sir,
Now, send attachments up to 25MB with Yahoo! India Mail. Learn how.
Posted: Mon Sep 14, 2009 3:24 pm Post subject: Re: Minimum Size & Thickness of Steel Section |
Thank you Sir for giving me valuable information as well as appreciating my effort.
after completing i will share it to you all for the review.
Thanks Again .
arulsteel wrote: | Dear Mr.Waqquar Bhai
arul(serc)
Respected Sir,
Joined: 21 Feb 2008 Posts: 5496 Location: Gaithersburg, MD, U.S.A.
Posted: Tue Sep 15, 2009 2:30 pm Post subject: Minimum Size & Thickness of Steel Section |
Dear Er. Ahmed and Er Pawar,
BIS is Govt. organization and it took more than 20 years to bring out new editions of IS 800:2007(earlier version 1984), and also IS 456:2000(earlier version 1978). How can you expect them to update all other codes, so quickly. There are many other codes and Handbooks, which are related to IS 800, such as IS 802, IS 806, SP 38, SP 1-5, SP 40, etc., We can only pray God for them to be revised. As far as I know, the work on revising these codes and Hand books have not been started. I believe revision work on IS 801 has started. My friend Dr Arul of SERC can through some light on it.
BIS will sell the old versions(Even ACI sells ACI 318-05, even now), as it will get revenue. These codes and Handbooks have also become very expensive!
Quote: |
Dear Mr. Ahmed,
I am pasting here a list of Codes related to the Stru Sections mainly 801 and 811 is partaing to the light section......
Posted: Wed Sep 16, 2009 3:21 am Post subject: Re: Minimum Size & Thickness of Steel Section |
Dear Er Waqquar Ahmad,
This is a good question. Many novice engineers specify steel sections based on their design, which are often not available in practice. It is better if you write to Sail and Tata Steel to get the steel sections rolled by them. My book Appendix A(available in CD) contains the available sections*I, channel, equal and unequal angles, and Tees) in the market. It also includes properties of Wide flange sections, Castellated beams, Circular tubes and hollow sections and cold rolled lipped channel and Zed sections.
Though the minimum thickness of steel provision is removed to allow the use of cold formed sections, proper painting/coating has to be used. They are found in the Durability section of the code.
Best wishes for your project,
Md Waqquar Ahmad wrote: | Respected Sir,
SUCHA SINGH SEFI Member
Posted: Wed Sep 16, 2009 3:49 am Post subject: |
Dear SAFIANS,
For the latest on revisions and other updating programmes of BIS one may visit BIS website www.bis.org.in.
THanks and regards
SUCHA SINGH |
hiren_patel SEFI Member
Posted: Tue Jan 18, 2022 10:36 am Post subject: PEB Structure |
Hello Sefians, I wanted to know that is there any minimum thickness requirement that we have to satisfy to design a PEB structural sections apart from limiting width-to-thickness ratio given in table 3 of IS800. As in practice, economy plays major role in reducing and deciding thickness of members instead of codal provisions. So, is there any guidance or restriction or good practice to follow to get the confusion solved?? |
vikram.jeet General Sponsor
Posted: Wed Jan 19, 2022 4:45 am Post subject: |
I think , SP 38 is not revised and is based on WSM and still active as enlightened by Er Pawar & Dr NS sir .
Minimum thickness of members is very important for durability of steel members , and prescribed maintenance standards ( periodic painting schedule) are generally not adhered causing rusting / deterioration
Exposure conditions of steel members must be kept in view . In Certain situations where maintenance & inspection is not very easy , eg steel pressure shafts in HYDROPOWER structures , Corrosion allowance is additional thickness to be added to design thickness.. |
Posted: Wed Jan 19, 2022 8:34 am Post subject: Re: PEB Structure |
Codal provisions need to be adhered and cannot be hindsighted for economy considerations .
Yes a design engineer always wish to create economical design but DESIGN IS NATIONAL , though analysis is Universal. It has to be done respecting the Country Codal requirements.
In case National Code is silent on certain provision , specialist literature or foreign Codes can always be referred for better and logical design. All tender documents generally incorporate such situations where National Code provisions are silent on certain aspect .
hiren_patel wrote: | Hello Sefians, I wanted to know that is there any minimum thickness requirement that we have to satisfy to design a PEB structural sections apart from limiting width-to-thickness ratio given in table 3 of IS800. As in practice, economy plays major role in reducing and deciding thickness of members instead of codal provisions. So, is there any guidance or restriction or good practice to follow to get the confusion solved?? |
