[ECONF] BIS - Drawbacks
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 1st June 2003
admin at sefindia.org
Guest
PostPosted: Tue Jul 22, 2003 11:17 am    Post subject: [ECONF] BIS - Drawbacks Reply with quote
This is a message from Prof.A.R.Chandrashekharan, which I am forwarding to
the e-Conference. It seems he had posted this message on the evening of
July, 20, 2003, a day before the e-Conference was supposed to start, so the
automated software on the server had rejected & not posted the message.
----- Original Message -----
From: "Prof. A. R. CHANDRASEKARAN" <arcs123@sify.com>
To: <econf@sefindia.org>
Sent: Sunday, July 20, 2003 5:47 PM
Subject: Re: [ECONF] BIS - Drawbacks
I had served on BIS committees as a member of BIS for quite a long time.
This is one insider view.
The set-up of BIS has not modernised and is not capable of producing new or
revised codes in a reasonabe time frame. Also, the committee membership is
drawn mainly from those near Delhi or to those organisations like CSIR whose
members are paid travel charges by BIS. Members from most educational
institutions are not paid travel charges Taking the case of IS:1893, Dept.
of Earthquake Engineering had interest that earthquake codes should be
brought out and hence subsided the charges and wrote the first draft in the
formulation of codes from 1960 upto 1984. Later on other institutions,
notably IIT-K joined in. Initially, the spacing was reasonable - 1962, 1966,
1970, 1975 and 1984.
I feel the enormous delay from 1984 to 2002 was due to problems of
agreement  in making Seismic Zoning Map. Even now, the zoning map is faulty
but we  have  to get along. The professional engineers were also not
forthcoming with  first draft of their own and only now have started
commenting on the drafts sent for wide circulation.
Quick response is possible ONLY and ONLY IF BIS activities on code become
web based. The old style is doomed for  failure.
Do we have  an alternative to BIS ? ACI brings out a code. Structural
Engineering of Association of California
brought out a code. Why not SEFI bring out a code [explanatory handbook,
recommendations for modelling, etc]. Then BIS could adopt it formally with
modifications. To start with such attempt could cover short topics - for
example "curing"  on which a lot of opinion was generated recently.  These
will be in the form of SEFI monographs.
More on seeing reactions, if any.
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 1st June 2003 All times are GMT
