Concrete block foundation
Kaustubh Vaishnav
PostPosted: Tue Apr 20, 2010 6:29 am    Post subject: Concrete block foundation Reply with quote
Dear all
Need your help in designing a fondation for Transformers
Transformers having weight 6-7 Tonnes,
Present practise is to use RCC transfomer plinth with columns, beams & slab,
I just want to know
Whether concrete block foundations are suitable in this case?
Concrete block foundations will take load of transformer?
In which case more quality control is required at site? RCC or concrete blocks
Which one is cost effective solution? RCC or concrete blocks
Is their any other alternative?
Attaching drawing for transformer plinth for your reference.
Thanks & Regards
Kaustubh
suraj
PostPosted: Thu Apr 22, 2010 4:16 am    Post subject: Transformer Foundation Reply with quote
Transformer Foundation<xml><o></o>
Please use Discussion Forum for technical questions as all would respond<o></o>
<o></o>
International practise is to use ordinary thick block of RCC say 1 x 1x 1.2 m depending on the size of transformer with nominal reinforcement.It would be a cost effective solution when the transformer is to be placed on ordinary height enabling placing the foundtion on or near ground.<o></o>
Load indicated is also too small & can be easily managed.<o></o>
Transformer foundation shall not be subject to moments @ ordinary level.<o></o>
Regards<o></o>
<o> </o>
Thanks & Warm Regards
Engineering & Arbitration
Kaustubh Vaishnav
PostPosted: Thu Apr 22, 2010 6:09 am    Post subject: Re: Transformer Foundation Reply with quote
Dear sir
We are placing the transformer not on ground.
we are placing on transformer plinth. Which is resting on foundation.
As you are suggesting RCC block it will more heavy as ht requirement is more.
Means we have to keep the transformer about 2.8-3.0 m ht from foundation top.
My problem was
1. Is it posible to use concrete block masonary fnd. for that ht i.e 2.5-3.0m?
2. Whether it will take load of transformer, considering vibrations.
3. In which case more quality control required ?( In case of RCC or block fnd.)
Plz guide me for proper solution, because my boss is saying tht for better quality
control we are practising RCC transformer plinth. Is it true?
KAustubh
<o></o>
Regards<o></o>
<o> </o>
suraj
PostPosted: Thu Apr 22, 2010 9:44 am    Post subject: Transformer Plinth Reply with quote
Transformer Plinth
Please, do not opt for concrete block walls 3 m high.
It is suggeted to include RCC plinth as planned for a better & reliable quality assurance & effective sustainability of structures.
Kaustubh Vaishnav
PostPosted: Thu Apr 22, 2010 9:56 am    Post subject: Re: Transformer Plinth Reply with quote
Ok
Thanks for guidence
But i was thinking of trasformer plinth resting on RCC slab which
will rest on block masonary.
my another qestion is that whether is it posible for me to
eluminate beams means slab resting on only columns.
is it posible ?
Plz refer drawing attached
Kaustubh
suraj wrote:
Transformer Plinth
suraj
PostPosted: Thu Apr 22, 2010 11:49 am    Post subject: Transformer Plinth Reply with quote
Transformer Plinth<xml><o></o>
I would not suggest columnless supports for the plinth due to structural requirement reasons.<o></o>
Yes, beamless plinth would do provided, the following provisions are ensured:<o></o>
Convert slab into beam.<o></o>
Provide double mesh by providing rebar mesh at top as well as at bottom.<o></o>
Increase slab thickness for meeting such requirement.<o></o>
Check for the bending moment, shear force as well as punching shear at column locations.
Check resistances against lateral forces.<o></o>
This provision would save beam forms.<o></o>
Regards<o></o>
<o> </o>
Kaustubh Vaishnav
PostPosted: Thu Apr 22, 2010 11:57 am    Post subject: Re: Transformer Plinth Reply with quote
Dear sir
Thanks a lot
for your valuable guidence.
I really apriciate ur practicle as wel as structural knowlege.
Thanks & regards
Kaustubh
Regards<o></o>
<o> </o>
