Purti ...
Posted: Wed Jun 01, 2016 2:48 pm Post subject: Staad truss model |
Hello engineers,
Have created truss staad 3D modal. and the building is with 40 T gantry. and top beams at truss bottom chord level are failing.
Please suggest review and suggest me options or corrections.
I am uploading model here.
Download |
Filename: |
truss model.zip |
8.72 KB |
Downloaded: |
1108 Time(s) |
Abhishek_Singh Bronze Sponsor
Posted: Mon Jul 25, 2016 4:11 am Post subject: |
I am working on STAAD and need answers to some questions. Will be grateful if you could help me out with these. I am very new to this software
1. Floor Diaphragm: Is master slave better or the method where we increase the Iy of beam to a high value? I don't know how to apply master slave. Can anyone help me with steps?
[Or should I model the entire slab with plate elements? In that case floor diaphragm will be automatically taken care of?]
2. Cantilever: I have to apply vertical earthquake load on a 15m cantilevered plate girder. How do I apply this? If I run staad then normal Fx and Fz is fine but I need a method to apply vertical earthquake in staad for this cantilever. How do I calculate lumped mass in the software for this?
3. Shear Wall: I have two identical models except for one difference that one is modeled with plates as shear walls and other one is modeled with surface elements as shear walls. question with this in mind are written in a, b, c below
a. Do I need to mesh surface elements and/or plate elements if I intend to only analyze the plates/surface elements and read-off the vertical stresses only for manual design of the same?
b. In both of these models I have not modeled any slab. So I have situations where slabs areas are bound by vertical edges of shear wall and hence the software is not taking "Floor Load" command. How to sort this out?
c. I read somewhere that surface elements are better to model shear walls. But if I intend to only extract forces and design by hand, is it fine to use any of these? Or does surface element have any distinct and un-ignorable advantage over plate elements for shear wall modeling?
Many Thanks,
Abhishek
smstoankur SEFI Member
Posted: Wed Aug 10, 2016 12:54 pm Post subject: STAAD OUTPUT |
I have designed a FOB for which the model is attached. During analysis of Purlins (as curved members), the maximum moments shown in the output(.ANL) file using MAXF ENV commands for Members no 801 to 809 is not matching with the maximum forces (read moments) in the post-processing mode.
Can someone please explain me the problem/error in this case.
Thanks & Regards,
Ankur Agarwal
228.9 KB |
Viewed: |
854 Time(s) |
311.15 KB |
Viewed: |
955 Time(s) |
Download |
Filename: |
FOB1.rar |
3.2 KB |
Downloaded: |
873 Time(s) |
24Emily SEFI Member
Posted: Sat Sep 10, 2016 3:05 pm Post subject: =) |
Hello, friends! If you'd like to write unique and original essays but lack experience at the moment, I'd recommend this source where you can find out useful information to develop such skills
http://bigpaperwriter.com/blog/essay-about-earthquake
rohit kumar prasad SEFI Member
Posted: Mon Sep 12, 2016 9:24 am Post subject: Re: STAAD. PRO |
P.K.Mallick wrote: | I presume there are engineers like me in this forum who are not conversant with STAAD.PRO operation.
But I am sure there are experts available in this forum who are quite conversant with STAAD.PRO.
For benefit of novices like me, Will somebody write step by step method of operating STAAD.PRO right from model generation,loading and design.
Example of a building will suffice.
Any volunteer ?!
Please come forward.
I know it is time consuming and requires considerable efforts.
Still I am hopeful that somebody will come forward. |
raviteja1111 SEFI Member
Posted: Sat Apr 08, 2017 7:08 am Post subject: |
Dear sir,
Please explain me about how to calculate the load for 1mtr it will take. for ..
1. 8mm
2. 10mm
3. 12mm
4. 16mm
5. 20mm
6. 25mm
kishorpss General Sponsor
Posted: Fri Apr 21, 2017 4:43 pm Post subject: |
While designing an auditorium of R.C.C. structure having sizes 60.00mtr X 15.00 mtr, the beam depth of 750mm spaning along width found safe in staad software.
But the same is not satisfying span/depth ratio as per clause no.23.2.1.
Please post your openion in this connection.
Is Staad is not able to chech the span/ depth ratio ?
Brgds,
Kishore Ku. Behera
sakumar79 ...
Posted: Sun Apr 23, 2017 3:17 pm Post subject: |
Dear Er Kishore,
STAAD does not check for deflection unless specifically instructed to. Please refer to the Design Parameters section of the manual.
Yours sincerely
Arunkumar
Posted: Mon Apr 24, 2017 2:07 am Post subject: |
Dear Arunlumar,
Thanks a lot for your valuable guidance.
Brgds,
Kishore
sm2345110 SEFI Member
Posted: Wed Apr 26, 2017 7:43 am Post subject: |
One of the best support for the STAAD Pro,
Thank You so much:)
Sharon Maxwell
CETPA Infotech Pvt Ltd
