ganesh_lakade SEFI Member
Joined: 25 Sep 2010 Posts: 9 Location: Sangli, Maharashtra
Posted: Tue Oct 12, 2010 11:01 am Post subject: HOW TO DESIGN FOOTING AND COLUMNS SUPPORTING PEB STRUCTURE |
DEAR SEFIAN,
I WANT TO KNOW WHAT IS THE PROCEDURE FOR DESIGNING THE COLUMNS AND FOOTINGS FOR SUPPORTING COLUMNS OF AN PRE ENGINEERED BLDG. AFTER GETTING AXIAL LOAD, MOMENTS FROM PEB SUPPLIER.
PLS HELP ME ON THIS. |
badamsundararao ...
Joined: 24 Dec 2009 Posts: 218 Location: KAKINADA ANDHRA PRADESH
Posted: Tue Oct 12, 2010 4:37 pm Post subject: Foundation design for P E B structure |
Dear friend
It will be quite similar to regular column and column footing design only but check for min. steel requirement in pedastals.
badam sundara rao. |
vandana_verma SEFI Member
Posted: Wed Oct 13, 2010 5:38 am Post subject: |
Dear Friend,
Foundation will be same as isolated foooting mainly , but in some cases when crane columns are coming and/ or spacing is much closer combined footing may come.
As the columns in pre engineered buildings start from ground floor level, lateral forces in case of wind & earth quake shall create some moments at foundation level depending upon foundation depth, which shall be taken care of.
regards,
vandana |
Posted: Wed Oct 13, 2010 6:17 am Post subject: |
Dear Friend,
regards,
vandana |
umeshrao ...
Joined: 23 Aug 2010 Posts: 573 Location: Bangalore, India
Posted: Sat Oct 30, 2010 2:19 pm Post subject: Re: HOW TO DESIGN FOOTING AND COLUMNS SUPPORTING PEB STRUCTU |
ganesh_lakade wrote: | DEAR SEFIAN,
Dear Ganesh,
If you browse thru' general discussions you will get an answer. It was deliberated quite well and quite a few contributed. Probably around mid September this year.
Regards Umesh Rao |
