problem in staad pro 2003
makarand at zentech.so...
Guest
PostPosted: Thu Nov 27, 2003 5:37 am    Post subject: problem in staad pro 2003 Reply with quote
Dear Mr. Jain
There is no way that a file runs in one folder do not runs in another folder
except a chance that you have very bad clustered Hard disk.
The problem is truly with your modelling data and parameter list. So I will
suggest to repeat commonds as required  for "response spectrum
displacements" with small portal model and you can check if portal runs
through, Then start putting more involved commands one after another or try
same portal logic with your model.
Makarand
nagaraju_pogula
PostPosted: Thu Nov 27, 2003 6:29 am    Post subject: problem in staad pro 2003 Reply with quote
Dear Jain,
Once I encountered similar problem.That time I found some mistake in the input file.Section sizes of some beams were given by mistake, as 230x600 m instead of 0.60x0.23 m.So please check your input file.
nagaraju.p
makarand@zentech.soft.net wrote:
Dear Mr. Jain
Makarand
