ranna ...
Posted: Fri Dec 05, 2003 4:16 am Post subject: EQ |
Generally RCC multistoried bldgs are with infill/filler walls.Steel structures which are built for power stations/chemical industries do not some times have filler walls. Hence for RCC structures with filler walls the infill wall formula has to be taken and for steel structures without infill walls the without infill wall formula is to be taken R.Anna
bhavsarak@yahoo.co.in wrote:
Quote: | Respected Sirs and Seniors,
I have one question regarding the calculating the time period for calculting the EQ, In code they have given two formula ,one is for when we not consider the the infill wall and one is when we consider the infill walls. Now in multi storey building what we have to consider? whether with infill wall formula or without infill wall fomula ? Which one and Why ?
Regards. Ashish.
