amit_sharma Progressive Member
Posted: Sat Dec 11, 2010 3:54 am Post subject: need help |
Hello. I need a help for designing of foundation where the water is practically comes out from ground level after some excacation. The structure is B+G+3 storey and the approx area is 1800 Sq-feet. What should i do with this kind of structure. Please Suggest me. |
umeshrao ...
Joined: 23 Aug 2010 Posts: 573 Location: Bangalore, India
Posted: Mon Dec 13, 2010 11:06 am Post subject: Re: need help |
amit_sharma wrote: | Hello. I need a help for designing of foundation where the water is practically comes out from ground level after some excacation. The structure is B+G+3 storey and the approx area is 1800 Sq-feet. What should i do with this kind of structure. Please Suggest me. |
Dear Amit,
Normally if water starts oozing from bottom of excavated pit and makes ground marshy, then use stone or bricks as soling material. Place the soling material in the pit and ram it until the material does not penetrate into ground and form hard surface. Lay pcc over the soiling material and proceed with the normal work.
Other normal practice is pump out the water from pit to drain away from excavated area.
Regards Umesh Rao |
Posted: Tue Dec 14, 2010 3:17 am Post subject: thanks |
Thank you so much sir..This information is much more helping for me. |
