s_n_surya at yahoo.com Guest
Posted: Thu Dec 25, 2003 4:54 am Post subject: query/frm-saripalli surya narayana |
dear sir use dry brick backing with lean motor -on sright wall . this we used at allwyn nissan in 1984 to get curved stair case bye surya
--- rasavina@yahoo.com wrote:
Quote: | hello memebers
i have a query regarding constrcution of a inclined brick wall.
Iam getting my house constructed in form of a diverging cone i.e at ground level it got a radius of 7ft 3 inches and at slab level it got a radius of 8ft 9 inches. so it is in form of truncated diverging cone. The columns are already cast in inclined at 80 degrees with horizantal.
now i want to start the brick work.. what is the most suitable and cost effective method in which i shall go for construction,.
I will be very thankfull to u if any one of them can help me out
with regards
sudheer
Times Square
ajith_jeddah SEFI Member
Posted: Thu Dec 25, 2003 6:06 am Post subject: query/frm-saripalli surya narayana |
Dear Mr. Surya,
I would suggest that you go in for a thin non load bearing ferro cement slab for the above purpose. They can be as thin as 4 to 6 cm and can be supported on tie beams at the sill level as well at the lintel level, leaving openings for the windows and doors.
To my knowledge, this wouldl be the most cost effective way in which the above problem can be solved. It will have sufficient strength and also be light in weight and will not create any structural problems.
Since you say that the columns have already been cast, it would be better to have these slab panels fixed to the columns using channels or angles. Another advantage would be the availability of additional space within the room as the wall width would be only 6 cm instead of the 23 cm for a brick wall. For the projections of columns inside the room, you may decorate them or paint them with a different colour from the wall and make it look prominent, which would add to the beauty of the interior.
Let us also wait for valuable suggestions from the esteemed members of SEFI.
Best regards, G. Ajith Kumar
_________________________________________________________________
