Impact factor of crane moving load
karuna67
PostPosted: Thu Jan 13, 2011 11:35 am    Post subject: Impact factor of crane moving load Reply with quote
If hanging load of a crane say 10 tons hits any object wihile swinging the boom. What will be impact of moving load in a fixed structure.
anshugoel
PostPosted: Thu Jan 13, 2011 3:55 pm    Post subject: Re: Impact factor of crane moving load Reply with quote
Calculate the Kinetic energy of the load i.e. 1/2*mass*square of velocity.
This is the energy input - into the structure. This is converted into work done i.e. force times distance - which will give you the force.
Alternatively, you can take impulse as force * impact time which is equal to momentum i.e. mass times the velocity.
the velocity can be calculated as distance travelled in particular time.
or if it is hanging load = you can get velocity = radius*angular velocity.
Use this force as impact load on the structure and then it is normal static analysis.
Hope this helps.
