ACCEPTANCE CRITERIA OF CONCRETE
Goto page Previous  1, 2, 3, 4 ... 9, 10, 11  Next
mks
PostPosted: Sun Mar 20, 2011 4:46 am    Post subject: Reply with quote
Here is the said circular
Mithilesh
P.K.Mallick wrote:
bijay sarkar wrote:
Further to add here that very recently, Central Vigilance Commission of India has issued a circular dated 07.10.2010 regarding non-compliance of codal provisions of IS 456 : 2000 for Design Mix Concrete and Acceptance criteria of concrete read with amendment no. 3 of 2007. I think all designers/engineers at field formations/contractors/developers should be aware of that.
regards,
bijay sarkar
Will you please attach that circular of Central Vigilance Commission?
Design mix Concrete.pdf
CVC Circular
 Filename:  Design mix Concrete.pdf
 Filesize:  289.77 KB
 Downloaded:  510 Time(s)
P.K.Mallick
PostPosted: Mon Mar 21, 2011 2:17 am    Post subject: Reply with quote
P.K.Mallick wrote:
Arvind Jaiswal wrote:
Here is the paper by Dr Iqbal Ali who wrote the Acceptance Criteria for IS:456 2000, this will clear all doubts. But I am not able to bring down the size to 256 KB as desired by Admin. Could someone help me or could I get e-mail IDs of persons who are interested to have this file I can mail the sme to them. Or in case Admin can help...!! The pDF file is 1.18 Mb.
P.K.Mallick wrote:
No response!!!
Arvind Jaiswal
Respected All
Kindly have a look on the attachment and put forth your observations.
Warm Regards.
Respected All
Here is a request to everybody. Honestly speaking this issue has bothered me a lot.I was finding it difficult to implement the "Acceptance Criteria of IS:456-2000" IN THE CONSTRUCTION SITE. Partly, in fact, I was responsible for that as I was unable appreciate the relations and differences between  specimen and sample. Mind sometimes does not work and for me it never works.
So I humble request to all experts here to have look on my latest attachment and examine it critically. After getting nods from all of you,I would try to implement that in construction site.
Sorry for bothering you all.
Warm Regards.
P.K.Mallick
p.k.mallick1962@gmail.com
P.K.Mallick
PostPosted: Tue Mar 29, 2011 2:29 am    Post subject: Reply with quote
P.K.Mallick wrote:
P.K.Mallick wrote:
No response!!!
Arvind Jaiswal
Respected All
Warm Regards.
Respected All
Warm Regards.
NO RESPONSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
P.K.Mallick
mks
PostPosted: Tue Mar 29, 2011 7:48 pm    Post subject: Re: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
Respected Mallick Sir & Senior Seafians
I have tried to write the acceptance criteria of concrete as per IS 456 -2000 which is attached here with.
comments of senior seafians is highly appreciated .
Mithilesh
P.K.Mallick wrote:
P.K.Mallick wrote:
P.K.Mallick wrote:
No response!!!
Arvind Jaiswal
Respected All
Warm Regards.
Respected All
Warm Regards.
Acceptance Criteria.doc
 Filename:  Acceptance Criteria.doc
 Filesize:  42.5 KB
 Downloaded:  320 Time(s)
mks
PostPosted: Tue Mar 29, 2011 8:47 pm    Post subject: Re: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
Respected Mallick Sir and Senior Seafians
I have attached here with the sample of calculation of Mean of the four non overlapping consecutive test results as per data considered by Mallick Sir
Comments of senior seafians is highly appreciated.
Mithilesh
[quote="P.K.Mallick"][quote="P.K.Mallick"][quote="P.K.Mallick"][quote="Arvind Jaiswal"]Dear All,
Mean strength.xls
 Filename:  Mean strength.xls
 Filesize:  26 KB
 Downloaded:  263 Time(s)
rajmane
PostPosted: Wed Mar 30, 2011 3:41 am    Post subject: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
30 MARCH 2011
Dear Shri Mithilesh
To decide on acceptance of any test data, we must have information on standard deviation of the concrete being used. The following is suggested in the Code :
9.2.4.2 Assumed standard deviation<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Where sufficient test results for a particular grade of concrete are not available, the value of standard deviation given in Table 8 may be assumed for design of mix in the first instance. As soon as the results of samples are available, actual calculated standard deviation shall be used and the mix designed properly. However, when adequate past  records for a similar grade exist and justify to the designer a value of standard deviation different from that shown in Table 8, it shall be permissible to use that value
Let us remember that each concrete mix in IS:456-2000 is assumed statistically to have 'population' of strengths represented by 'Normal Distribution Curve' and the concrete strength characteristic is defined by two parameters - standard deviation and characteristic strength (indirectly the population mean strength). Without knowing standard deviation, acceptance criteria application would be incomplete for any test data!
With regards
N. P. Rajamane, Head, Centre for Advanced Concrete Research, SRM University, Tamil Nadu (Former Head, Advanced Materials Lab, CSIR-SERC) rajamanenp@yahoo.co.uk (rajamanenp@yahoo.co.uk), Mob:9840076821
--- On Wed, 30/3/11, mks <forum@sefindia.org> wrote:
Subject: [SEFI] Re: ACCEPTANCE CRITERIA OF CONCRETE
Date: Wednesday, 30 March, 2011, 2:17 AM
Mithilesh
P.K.Mallick wrote:      P.K.Mallick wrote:      P.K.Mallick wrote:      Arvind Jaiswal wrote:  Dear All,
P.K.Mallick wrote:
No response!!!
Arvind Jaiswal
Respected All
Warm Regards.
Respected All
Warm Regards.
NO RESPONSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![/color:5004e8913b]
Download Attachments:
Mean strength.xls
thirumalaichettiar
PostPosted: Wed Mar 30, 2011 7:29 am    Post subject: Reply with quote
Yes, it is true as stated by Dr.Rajmane we should know the standard deviation and it is good to refer IS Code,ACI and very good book on PROPERTIES OF CONCRETE BY ADAMNEVILLE for more guidance.
T.RangaRajan.
rajmane
PostPosted: Thu Mar 31, 2011 7:32 am    Post subject: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
31 March 2011
Dear Sefians
What does exactly Shri Mithilesh want? What kind of comments? Are not the clauses clear? We can say that acceptance criteria of concrete as per IS 456 -2000 is based on the assumption that the concrete compressive strength population of any given concrete can be considered as a random vaiable which can be broadly represented by standard 'Normal Distribution' curve.
Thanking you all and with regards
Yours sincerely
N P Rajamane
Head, CACR, SRMU (Ex-SERC)
Mob 9840076821
Date: Wednesday, 30 March, 2011, 1:18 AM
Mithilesh
P.K.Mallick wrote:
No response!!!
Arvind Jaiswal
Respected All
Warm Regards.
Respected All
Warm Regards.
NO RESPONSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![/color:a7155c5b37]
mks
PostPosted: Thu Mar 31, 2011 6:14 pm    Post subject: Re: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
Respected Sri Rajmane Sir,
Thanks for  your response and comment.  I  do agree with you Sir, but as far as IS 456 – 2000 is concern, Table 11 (Clauses 16.1 and 16.3) says that – In the absence of established value of standard deviation , the value given in Table 8 may be assumed, and attempt should be made to obtain results of 30 samples as early as possible to establish the value of standard deviation.
Sir, Actually I want to say that  how to calculate the Mean  of 4 Non –Overlapping  consecutive test results and come to conclusion that, the concrete represented by these test results will be accepted or not as per IS 456 – 2000.
Let us consider an example –
Grade of concrete is M20.
Suppose in a building project, there are 30 footing each having  6 cum concrete. And 5 footing has been casted per day. If we take  3 samples per day then total no of sample will be  18 Nos.
The analysis is given in attachment.
I request you for your comment in this regard.
Mithilesh
[quote="rajmane"]31 March 2011
Dear Sefians
Yours sincerely
N P Rajamane
Mob 9840076821
Mean_ strength.xls
 Filename:  Mean_ strength.xls
 Filesize:  26 KB
 Downloaded:  359 Time(s)
mks
PostPosted: Sat Apr 02, 2011 1:21 pm    Post subject: Re: ACCEPTANCE CRITERIA OF CONCRETE Reply with quote
NO RESPONSE  ????????????
[quote="mks"]Respected Sri Rajmane Sir,
Mithilesh
Page 3 of 11
