Different grades of concrete for columns and beams
er_spsvasan
PostPosted: Sun Feb 08, 2004 3:00 pm    Post subject: Different grades of concrete for columns and beams Reply with quote
Hello Rahul Jayant Kulkarni,
In your message dated Jan 14, you had mentioned that when the concrete strength in beam is less than the concrete strength in column, some international codes permit the usage of lower grade concrete at the beam-column junction. I shall be very thankful if you can kindly give the references for the same?Thanking you and with regards,S.P.Srinivasan
