rajneesh_jindal SEFI Member
Posted: Fri Apr 22, 2011 7:10 am Post subject: Staad Pro-2007 Designs as per IS 800/2007 or IS 800/1984 |
Please help
i have staad pro 2007 version.whether it designs as per IS 800-2007 or IS 800-1984?
and what about Staad pro v8i? |
nnsivakumar ...
Posted: Fri Apr 22, 2011 7:36 am Post subject: |
Hi,
STAAD.Pro V8i has IS 800-2007.
Thanks,
siva |
Kishor Patil SEFI Member
Posted: Fri Apr 22, 2011 12:12 pm Post subject: |
but it is not doing shear check properly. Its does only by considereing allowable shear stress and not by using member property
kishor |
gpsarathyy ...
Posted: Fri Apr 22, 2011 2:36 pm Post subject: |
Please check the STAAD DETAILED design in which the clause no. will be given - check that clause no. with the new code if it matches then OK.
STAAD PRO V8i - series 2 - does the design as per IS 800 2007.
G.PARTHASARATHY
CHENNAI
GPSARATHYY@GMAIL.COM |
fazilat.zaidi SEFI Member
Posted: Tue Apr 26, 2011 5:09 am Post subject: Re: Staad Pro-2007 Designs as per IS 800/2007 or IS 800/1984 |
Dear Friend,
Staad 2007 is not capable of designing as per IS-800-2007.
Staad pro V8i had a provisions for IS-800-2007, but result obtained from is not satisfactory,
I would suggest plz go for latest staad version "Staad pro v8i ss2"
Note:- Always have a manual check before making any decision. |
