Sesmic loading problem
Goto page Previous  1, 2
RAHULGEHLOT2009
Location: Mumbai, Ratlam, Ujjain, Kurukshetra, Kota, Jodhpur, Jilling Orissa, Delhi, Noida
PostPosted: Wed Jun 01, 2011 4:07 am    Post subject: Reply with quote
Dear
skarambam,
                             I am not clear of the question, you are confused about perform analysis and change commands and you have used PDELTA ANALYSIS in your model.
can you please explain you question.
regards,
rahul gehlot
skarambam
PostPosted: Fri Jun 03, 2011 4:31 pm    Post subject: Sesmic loading problem Reply with quote
Rahulji,
I was trying to reply but something is not going well between the website and me. My postings are not appearing properly in the forum. It's neither coming as individual reply/posting nor it is appearing in the digest.
Coming to my original problem let me explain it this way:
I am attaching the modified file herewith.
Actaully I run the program with the command " PERFORM ANALYSIS and CHANGE" after each EQ loading in the first case and
in the 2nd case I tried the program without the above command.
As told ealier in the forum by experts it was not suppose to give any difference other than omiting of warning. BUt in my case I found that the steel required for the columns designed are showing huge difference between the two results. It is getting me confused. I need everybody's help in guiding me thru this problem.
Sunitikumar
gpsarathyy
PostPosted: Sat Jun 04, 2011 4:05 am    Post subject: Reply with quote
Dear Mr Sunitikumar,
Are you trying for the P-delta analysis, there only CHANGE command will be used to take the deflected shape of the structure and its stiffness in the calculation.
In regular analysis CHANGE command is not required.
G.Parthasarathy
Chennai
GPSARATHYY@GMAIL.COM
RAHULGEHLOT2009
PostPosted: Mon Jun 06, 2011 5:35 am    Post subject: Reply with quote
Dear Suniti,
                  There r many error in ur model. i have corrected to some extend.
mainly
  1. Always use LOAD LIST command,
  2. Damping 5%
  3. if u r not using joint weights and defining the seismic loads as in ur model then remember to define loads in sequence as self weight, member weight, element weight, reference weight and then floor weight. other wise it will give error.
  4. for designing members u have to use some more parameters.
  5. also provide time period parameters px pz as per IS 1893
I have not reduced live load for seismic load as (DL +0.25LL). please correct it
here is the some what improved model . AND SEE THE COL. R/F IS NOT CHANGING IF WE USE perform analysis and change COMMAND OR NOT.
If you have problem posting you can mail me at rahulgehlot2006@rediffmail.com.
regards,
rahul
Page 2 of 2
